New diesel question
Catalina 320 Dana Point
Wide Open Throttle, maxxed out
you can almost use the temperature gauge as a guide in many boats. For mine low cruising speed 4+ Kts = 160 degrees, 180 degrees + near top (5+ Kts) depending on sea conditions.
Oct 15, 2004
33
- - Victoria, BC
How critical to correct overpowered prop ?
I'm in my first season of ownership (28' Sunstar), with a 2-cyl volvo penta 2002, very recently rebuilt. Prop needed changing and the one that I got was the same as the previous one except it has some cupping shape in the blades, making it overpowered, apparently. Rated for 28-3200 WOT under load, I can only get 2500. Mechanic suggested I might be OK running at about 2000 for the season and get the blades pounded flat when I put it on the hard next spring. Does this sound OK to you more expert guys? 2000 is 80% of actual WOT and 71% of low end of recommended WOT and 67% of midrange of recommended WOT. Hate to have to pull it out of the water mid-season. What think ye? Did another calculation and wondering if I should run around 2200 instead of 2000? This would be 88% of actual WOT and 73% of the mid-range of recommended WOT.
David W
m paxman
You might check with some of the other Sunstar owners in the area. We keep our boat (not a Sunstar) in Sidney and I have seen a number of Sunstar 28's in the North Saanich marina.
