New Coupling and PSS
79
Catalina 30 Boston MA
I am installing a PSS dripless and am replacing the coupling while I'm at it. Willl I be able to put the new coupling on my original shaft? I have a 1985 Catalina 30. I saw on MaineSail's site that the new coulping will need to be machined. So will the shaft need to be as well? If that is the case and I need to remove the shaft should I replace the cutless bearing and our have the prop turned? I know that is a lot all at once but any help would be great!!
Feb 6, 1998
11,772
Jay dog
Yes the coupling and shaft should be fitted and faced. The facing will most likely be good, though I have seen it out, but the fit over the shaft is critical. The shaft to coupling fit is generally done by hand and can take a bit of time. They can also check the shaft for runout while you're there. H&H is good and they are on the North Shore in Salem.
