New Combination Steaming Deck light
jfmid
Jan 31, 2010
152
Oday 27 LE Manahawkin, NJ
From what I have been able to figure out you do not want your anchor light on at the same time your steaming light is on when motoring at night.
I guess I'm not as clear as I thought I was. Maybe there IS something to what my wife says!
No, I'd just like to light the anchor light and the deck light separately. I have the standard red/green bow lights and white stern lights. I just wasn't sure how it's "suppose" to be done. The wiring I pulled out was a MESS so I couldn't follow it.
Pull a 16/3 wire to one of the combo lights (Aquasignal 25 for example) so that you can turn on steaming light or the deck light independently. I'm assuming you can turn your anchor light on/off independently also.
see wire example in link below - not saying this is best price or where you should buy
http://shop.genuinedealz.com/Items/...G Marine Tinned Boat Cable Wire - Round 25 FT
Another option is to place spreader lights (more involved) but you have to decide just how much lighting you want.
Good luck
Apr 8, 2010
2,230
My boat is also 34' long. We have a masthead all-around anchor light. It used to be a high-wattage twin-bulb Perko. When I replaced all the wiring along with the standing rig in '02 the masthead anchor light was changed over to an LED version. Works great.
Since the original ('88) steaming/foredeck combo light was pretty much ruined by UV, it was replaced with the Aquasignal light like the second one in your pictures (with it's "flaps").
Good light, but it seems to burn out the high-intensity deck light every year or two.
We replaced all the old wire with tinned #14, but could have saved some weight aloft and made the wire run a lot easier with #16 or 18 for that new LED light at the top.
Something to think about as you spec out the project.
And yes you do want separate switches for each light. My panel has separate breakers for every circuit, bet yours does too. :)
Regards,
LB
Oct 26, 2008
6,432
Catalina 320 Barnegat, NJ
dscribner, wiring refresher ...
Basically, most of us (with a combo steaming/deck light) will have an all-around anchor light at the top of the mast and the combo at mid-mast. Yes, the three lights should work independantly. The all-round at the top is on just when anchored, the steaming light is on with the bow lights and stern light when motoring only - not sailing at night. When sailing with bow lights and stern light on, the steamer is off. The deck light is for utility only, and is most likely going to be used when anchored or moored. It will ruin you night vision if you have it on while sailing or motoring so it is not a good idea to have it on then. I suppose that if you are in a congested area and there is some trepidation that you are not being seen, then it could be used to warn others that you are in the area and wish to be seen, but I wouldn't recommend it for that general purpose.
All that said, I wanted to simplify my wiring to some extent so that I could use a four prong plug at the mast connection. Obviously I have 3 positive leads going back to my switches. I will acknowledge that it is preferable to have a separate negative for each positive going back to the negative buss, but that would mean a 6 prong plug. Besides, if I'm not mistaken, the combo (mine is Hella) has an internally spliced negative lead. For positives, I have 2 - 16 guage wires (for the anchor and steamer) and a 14 guage for the deck light because of the length and the 20 watts. I have a 16 guage negative coming down from the anchor and a 14 guage negative coming down from the combo. Above the plug, I splice the 2 negatives to a single 12 guage negative. That way I have 3 pos and 1 neg for the 4 prongs. The 12 guage negative is all that runs back to the buss. I feel comfortable with this primarily because there is no need to have the 3 lights on at one time. I normally use the combo only when I'm on the mooring anyway so I typically have only one of the lights on at a time.
When I'm anchoring, I just use my 10,000 candle power spotlight to annoy everybody else around us! (Just Kidding!)
Jun 6, 2006
6,990
for true annoyance...
you need to use the 3,000,000 candle power spot. Gets them out of the cabin from 1/2 mile away!!:D
"My eyes are burning"
