New Combination Steaming Deck light
Blitz
Jul 10, 2007
722
Seidelmann 34 Atlantic Highlands, NJ
I'm hoping for some advice and recommendations on a combination steaming (or masthead) / deck light. I currently have a eighties vintage deck light (shown attached to mast since the mast is down for the winter) that served me well but it's not very bright. I would also like to get the combination light.
One of obvious choices are the AquaSignal series 25, but not sure if the deck light will be much brighter than what I have. The foredeck light is 20 watts.
http://www.aquasignal.info/aquasignal_us/files/content/series_25.pdf?id=183
Other choices I am seriously considering are the Hella 8504 since it has a 55 watt deck light - is this too much or will it be good - also, not sure the longevity of this light.
Another light I'm considering is the Hella 8505 but I believe this one only has a 20 watt deck light.
Or should I go for the gusto with the AquaSignal 4104 which looks more rugged, and has the 50 watt foredeck light. (is the light housing too large???) I'm seriously considering this but one of the more expensive - which I don't mind as long as it's good.
http://www.aquasignal.info/aquasignal_us/files/content/series_41.pdf?id=185
My boat overall length is 34', I have a Kenyon mast. I'll be rewiring everything that goes up the mast. The light will be mounted below the spreaders, about 12' off the deck. The same location as the current light. Above the new light I will mount e a tri-lens radar reflector. I do not have a Radar Dome.
Any recommendations or lessons learned with the suggested lights would be helpful, or if you have any other suggestions.
Thanks all for your help.
Alan
4,174
Hunter 35.5 LI, NY
I have the series 25 on my boat. 20W is plenty of light. I'm not reading a novel or doing brain surgery, it's for dealing with anchoring gear and headsails. Consider just what you need the light for.
...just my 2 cents.
Dec 4, 2006
281
Hunter 34 Havre de Grace
Another Series 25 here.
Remember the more light you expose your eyes to, the more night vision you temporarily lose.
It takes longer for your body to make visual purple (which gives you low light sensitivity) than it does to destroy it.
Oct 26, 2008
6,432
Catalina 320 Barnegat, NJ
I chose the Hella 8505 when I replaced lamps for my Kenyon mast. I am also happy with it. I find that there just isn't that much need for a deck light and I soon realized that even a quick use of it while underway destroys night vision substantially for several minutes until your eyes readjust. 20 Watts is plenty of light for any task when anchoring or mooring.
Blitz
Jul 10, 2007
722
Choice - based on trip to boat yard
After looking around in the boatyard I think I've narrowed down my choice. Although the Aqua Signal Series 25 combination light looks great and most likely meet my needs, Im not certain why they don't have a bottom lens on the foredeck light. It seems that if it got wet or dirty, the bulb would burn out prematurely.
Based on this, I think the forespar light might be a more rugged choice.
http://www.forespar.com/products/sail-combination-deck-bow-light.shtml
Any thoughts on either?
Aug 26, 2006
13
- - ala wai
on my old columbia 45 i had the one like your last picture. it always worked great. lit up the entire foredeck. no glare in your eyes. great for sail handling at night.
Beneteau 323 Annapolis MD
Im not certain why they don't have a bottom lens on the foredeck light. It seems that if it got wet or dirty, the bulb would burn out prematurely.Any thoughts on either?
I had never used the boat at night, so only had the deck light on to test that it worked. Nonetheless, it burned out in only 3 years of non-use. No lens makes it easier to change the bulb, if for no other reason.
Blitz
Jul 10, 2007
722
A bit pricy Roger. Also, don't see the need for an LED for a steaming light since the engine is of running. But pretty cool.
Blitz
Jul 10, 2007
722
Did you mean the Aqua Signal big one?
3,562
Endeavour 32 Portland, Maine
$900 plus bucks. That's why the LOL.
I didn't see the need for an LED steaming light either until my bulb burned out three days into last season and I avoided night motoring all summer.
I'm looking for an LED steaming light at a reasonable price but they are hard to find. The Aqua Signal combination shown above is just retrofitted with an LED bulb. Not having spring contacts to corrode and weaken is another plus for LED's in my book so I'd like to find a hardwired light like my other navigation lights.
I like that combination unit though and may have to go with it if something else doesn't turn up by spring.
Jun 6, 2006
6,990
LEDs for steaming lights
Well if you have one of those electric motors it could reduce your electrical consumption so you can get a boat length further down the bay before the motor dies
I could not resist.
Jun 6, 2006
6,990
As good an engineer as you are Roger I'd have thought you would have already designed one. The LEDs have pretty well defined light angles and "hiding them" from the wrong angles would just be moving them into a hole or behind a wall. Pretty basic stuff.
Nov 22, 2008
3,562
I could design it but I couldn't afford to get it USCG certified.
BTW I've emailed Aqua Signal to ask about their combination units. They are shown for sale elsewhere on the web with LED "bulb' in them but it doesn't say they are Aqua Signal. If Aqua Signal sells an LED version, I can't find it on their web site. Leads me to think they are not certified.
There have been previous threads about the inadvisability if sticking LED "bulbs" into certified fixtures. In line with the current lawsuit threads, think of the hay some smart ass's lawyer would make after his client Tboned you on the portside in the dark if your steaming light wasn't certified.
Nov 9, 2008
1,338
Let me ask you guys (and girls?) this.
Last year I yanked all the wiring out of my mast. It was all aged anyway. I put a white masthead light on the top of the mast (go figure) (ref Capt'ns Log) and wired just that. Before that I had a streaming light on the front of the mast with a deck light just below it. Right now, the deck light is non functional. When I get around to wiring that, should it come on at the same time as the masthead light? I don't like that because it is my anchor light and most of the time, that's all I want on. Does this make sense?
Also, before I snaked the wire through the mast, I got 3/4" foam backer rod, cut it into short chunks then strung it on the wire like marshmallows on a string. The wire is now completely silent at night. My lovely bride likes that. With my snoring, what does it matter?
`Marc
Apr 14, 2007
4
- - Des Moines, Iowa
Aqua Signal only sells their festoon bulbs and the like their LED lamps come from Dr. LED. I have the series 25 for all my navigational lighting with the LED lamps in them. One night last summer a buddy of mine was about three miles away and he said he could find me because my anhor light outshone everyone elses. Marc
Nov 22, 2008
3,562
As previously reported, I emailed Aqua Signal to inquire whether their combination steaming / deck light was USCG approved with an LED bulb. Their email came back with this at the bottom
Be aware, any disclosure, copying, distribution or use of the contents of this information is prohibited.
so I can't tell you their response. However, I can confirm that no USCG approved LED version of this fixture is available.
I suspect that $880 of the price of this fixture:
http://www.dedicatedmarinesupplies.com/products/Masthead-2nm-w{47}-Integrated-Decklight.html
is for the cost of USCG approval.
Isn't this a great country?
jfmid
Jan 31, 2010
152
Oday 27 LE Manahawkin, NJ
From what I have been able to figure out you do not want your anchor light on at the same time your steaming light is on when motoring at night. Both lights on would suggest that your vessel is over 50 meters in length.
The confusion seems to begin when the question of motor or sail is used at night. Under sail alone (sailboats less than 20 meters) you need only display red and green forward with white aft. (I'm not listing degrees visible and such)
For Motor at night whether in a sailboat or powerboat you must show a white forward and aft (all around or some combo that makes up 360 deg) in addition to red and green. There is a distinction based upon size of vessel under power at night. I'm not going there with this either.
I was advised that a mid mast steaming light is sometimes more likely to be seen than an anchor light when underway and the logic of this made sense to me. Especially in a crowded anchorage where people might not be looking up but rather looking straight out a light at the top of a tall mast might get missed.
So I am doing exactly what you are doing now (my mast is down and apart) and replacing my anchorage light with an LED visible for 3 nm and putting a combo light on the mid mast for steaming / deck illumination. All will be independently controlled so that I dont confuse others and am in compliance and as safe as possible.
Here is a link that shows graphically the requirements but I would verify with the USCG regs to be sure.
http://www.boatingbasicsonline.com/content/general/4_2_b.php
Check out Maine Sails post on crimping tests. Good info if your doing this yourself.
Nov 9, 2008
1,338
I guess I'm not as clear as I thought I was. Maybe there IS something to what my wife says!
No, I'd just like to light the anchor light and the deck light separately. I have the standard red/green bow lights and white stern lights. I just wasn't sure how it's "suppose" to be done. The wiring I pulled out was a MESS so I couldn't follow it.
