I'm hoping for some advice and recommendations on a combination steaming (or masthead) / deck light. I currently have a eighties vintage deck light (shown attached to mast since the mast is down for the winter) that served me well but it's not very bright. I would also like to get the combination light.
One of obvious choices are the AquaSignal series 25, but not sure if the deck light will be much brighter than what I have. The foredeck light is 20 watts.
http://www.aquasignal.info/aquasignal_us/files/content/series_25.pdf?id=183
Other choices I am seriously considering are the Hella 8504 since it has a 55 watt deck light - is this too much or will it be good - also, not sure the longevity of this light.
Another light I'm considering is the Hella 8505 but I believe this one only has a 20 watt deck light.
Or should I go for the gusto with the AquaSignal 4104 which looks more rugged, and has the 50 watt foredeck light. (is the light housing too large???) I'm seriously considering this but one of the more expensive - which I don't mind as long as it's good.
http://www.aquasignal.info/aquasignal_us/files/content/series_41.pdf?id=185
My boat overall length is 34', I have a Kenyon mast. I'll be rewiring everything that goes up the mast. The light will be mounted below the spreaders, about 12' off the deck. The same location as the current light. Above the new light I will mount e a tri-lens radar reflector. I do not have a Radar Dome.
Any recommendations or lessons learned with the suggested lights would be helpful, or if you have any other suggestions.
Thanks all for your help.
