Purchased (April 16, 2012) a 1982 Catalina 30/hull number: 2706 now slipped in Key West, Florida.
Had problems with the engine..a couple of lessons learned for those of you new to marine diesels..as I was-
1. A great deal of water and debris in diesel tank. Completely pumped out the tank and cleaned the inside (pumped cleaned diesel into the tank and at the same time "sucked" the diesel out)..$85.00
2. Due to the water in the tank, apparently burned out the fuel pump (as diesel acts to lubricate the pumping cylinder)..replaced at $112.00
3. Water was not coming out of rear after several minutes of running at near temp to open newly installed thermostat; although, the impeller looked fine..no use over a period of time damaged the fins on the impeller; Replaced and water flowed as normal. Thermostat: $26.00 Impeller: $30.00
4. I purchased a handheld heat gun to measure temperatures at various parts of the engine and to validated the temperature gauge as correct..which is was.
Fortunately, there was a Kubota dealer in Key West who was very familiar with the Universal engine. Using the Z500 engine stamp (corresponds with the tractor engine parts list) on the oil dip stick, I was able to purchase the thermostat, corresponding fuel pump at a reduced price over traditional marine engine parts dealer.
In summary, the engine and overall condition of the boat was in excellent condition..the previous owner from upstate NY took the boat out each winter...had almost no contact with salt water until moved to Panhandle, Florida..then down to Key West where I purchased the boat.
Back downrange..hope to get back in late October/Randy
