New Boat
4
Oday 22 Ooltewah, TN
We live on a small inlet off of Chickamauga lake in Tennessee. I am looking at an Oday 22 as my first real sailboat. I can play in the inlet, but to get to the real lake I have to pass under a bridge. How muchb above the water is a 1983 Oday with the mast down and how easy is it to raise the mast by myself?
Mark P
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
Mark P
Mark,
The 1983 O'Day 22 is a fractional rig with a keel/centerboard and it was one of the last 22s they built before they came out with the O'Day 222. I couldn't tell you the height from the waterline but the mast on my 86 O'Day 222 is 27' high standing on top of the cabin and it's also a fractional rig.
As for mast raising/lowering, I think that if you can rig up a temporary mast crutch in the stern to hold the mast from hitting the cabin top, you could probably let that mast down by hand while standing on the companionway hatch with the aid of a rope attached to your jib halyard, going through a sheave on the bow plate and back to you. The rope has no advantage until the mast is part way up. As the mast lowers, the angle of the rope becomes too acute and this is where shoulder power comes into play.
If this boat has a roller reefing furler, I wouldn't advise using this method of mast raising/lowering though without a Gin Pole. Gin Poles are great but they are kind of time consuming to set up for what you have planned. With a mast crutch in the stern, (mine has a small roller in the crutch) you leave your stays connected except the fore stay, and raise the mast from the stern. The boom can be inside the cabin with the sail attached to it. Once you get the mast up, you simply pull the rope up tight which is attached to the jib halyard, and bring it around the mast above the gooseneck fitting so it doesn't slip down, and tie it off to one of your bow cleats. Then you can attach the fore stay. The wind always needs to be coming directly from the stern when you do this and the boat needs to be level. Hopefully some idiot won't come by and raise a large wake on you when you're in the middle of this mast raising/lowering. Check out my "Owner Photo Album" for pics of the Gin Pole and mast crutch. Like I mentioned, they work great but they are time consuming.
Joe
Nov 27, 2010
4
Thanks for your reply. How do I get to your photo album? With the mast down, how tall is your boat above the water line? My problem as mentioned before is that I have a small inlet to learn how to sail in, but to really sail I have to go under a bridge that is way to low to have the mast up and maybe too low even with it down if it is much above the cabin top.
Thanks
Mark P
markparson@aol.com
Jun 3, 2004
269
Oday and Catalina O'Day 25 and Catalina 30 Milwaukee
Getting the mast up and down
Hi Mark -
Like Joe, I have a 222. Mine was built in 85, and it has the Dwyer mast which is 28 foot long. I would estimate that the distance from the waterline to the cabin-top is about 3 feet which puts its 31 feet above the waterline. Getting a mast raising system is important, especially if you want to raise the mast alone. If you have two people, it's easy to do it without a gin-pole type system. I always use the mainsheet attached to the halyard and raise it with the mast initially in a crutch at the stern. With one person supporting the mast from the cabin-top, you get the angle of the mast up enough to use the mainsheet to pull it up the rest of the way. With a gin-pole, you can use the halyard right away. The key is setting it up in such a way that the mast does not shift side to side on the way up. My system was not bullet proof but I was always able to muscle it up solo if I needed to do so.
I now have a 25 foot O'Day so that option is no longer available, and I did come across a nice simple system on this site that I'm going to replicate. It's in a recent post:
http://forums.oday.sailboatowners.com/showthread.php?t=124325
I think you will like the O'Day 22. It's a great little boat, and I did a lot of sailing on mine over the years.
Best regards,
Dave
O'Day 222 and O'Day 25
Jan 24, 2005
4,881
Thanks
Mark P
markparson@aol.com
Mark,
All you have to do is click on to my handle, "Trinkka" and click on to "View public profile." Then look for my photo album under "Trinkka's Mods" at the upper right hand side of the screen.
