Hi Everyone!I just purchased a 1975 Albin Vega a week ago and already loving sailing it on Lake Michigan! Unfortunately, I am a little spooked by the engine...The prior owner prepared everything for the spring launch so I don't have as much first-hand experience with the motor as I would like. It still has the original Volvo Penta MD6A with the combi-drive. It had been motored at least 3 hours this month prior to this weekend with no issues. The tank had about 2 gallons of diesel from last year. The oil was changed last year and the level looked good.I added 2 more gallons of fresh diesel this weekend and everything seemed fine: no excessive exhaust smoke, it started easily, it ran smoothly. After our sail, we motored into the harbor (about 15 minutes to the harbor mouth) and everything seemed fine until we noticed a slight smell of wood burning as we entered the channel. We took about 15 minutes to motor toward our slip and continued to smell the odor despite the motor performing fine. Once at the dock we opened the motor compartment and found the culprit-- the interior of the door/step at the bottom started to burn including some of the old insulation. It looks a little tight in there and appears that this may have also happened before. I am not sure if it is an issue with the insulation touching the motor and then igniting the wood, if the motor over-heated (maybe a filter got clogged), or if we are looking at a dangerously old engine in need of repair/replacement. I fired up the motor about an hour later and again it started right up. It was a very hot day and we were having to power through some plant debris and 3-5' waves... I am really hoping this is a (scary but) minor glitch.Any ideas or advice would be greatly appreciated,Ross Fiersten
