Y'all sure like to do things the hard way!
If you do it on a regular basis, you shouldn't ever have to do anything more than blast out the thru-hull with water through your hose nozzle to keep the vent open. It's only when you neglect it and let it become blocked that it's necessary to resort to "extreme" measures to clear it. If you accidentally overflow your holding tank, rinse the tank out when you pump out, then overflow the tank out the vent with clean water to rinse out the vent line and the thru-hull--something you should do after every 4-6 pumpout/dumpouts anyway. As for how to clear a vent that you've neglected until it's become so cloggged up you can't open it by poking around the thru-hull with a screw driver and/or flush it out with water, I can't tell you the "best" way because vent lines aren't the same on all boats. I CAN tell you that you try some of the suggestions I've seen here at your own peril, though! IMO, if it's that bad, you'd be better off just cleaning out the thru-hull and replacing the vent hose.Some of y'all get upset that I harp more on prevention than cure...but 99% of cures wouldn't be necessary if you hadn't neglected prevention...and preventing problems is always easier--and usually cheaper--than curing 'em.
