right here you can get the 260 manual
If you click on resources (it is one of the links above) in the drop down menu select reference library, then select manuals, and you will find a 260 manual. The 260 is slightly newer (but not better) than our 26 boats, the main difference is wheel steering, and add a fwd hatch, but delete a center hatch/window. other than that the rigging is pretty much the same, as is the mast raising procedure, although the 260 has mast struts instead of baby stays to hold the mast steady when raising/lowering it..I bet a brandy new Manual could be obtained from Hunter themselves..I could not find one on the web, it is nice to have because it shows wire diagrams,etc..
