How did you make out? Is the faucet out?
Haven't touched the faucet. I'm starting at the other end of the system - pulling the lines on either side of the water pump as they look pretty disgusting. I want to add a pressure accumulator near the pump so it won't cycle so much. The stalling is giving me a bit more time to look at the faucet situation and related plumbing. I also want to drain the tank to see if the Blue Sea gauge actually will show anything other than full. I'd gone through the calibration routine, but am not sure it's right.
On an even more-unrelated note, I'm getting coolant showing on the back (output side) of the Yanmar, so I probably should solve that before cutting holes in the counter. Engine's running fine. No coolant in the oil. Probably just a loose hose clamp, although I've not seen any obvious source.
Ordered a new coaming insert (for the engine controls) from SSI to replace the original that's coming apart where it fastens. It's larger, so lots of new gauge opportunities. Oh, the plumbing/wiring they will require!
Plus, I've got a new pitbull that's rapidly destroying our house. So far, though, she likes the boat, but then she hasn't seen my sailing skills yet.
John
