Tito C.
I bought my O'day 25 recently, and even though for the most part is in good shape, one day while wandering under the cockpit, I noticed a 4" crack on the inner part of the transom. To my surprise when I touched the surface it felt soft, and that's when I noticed four bolts right above the crack. Oce out side of the boat I realized these were the bolts attaching the outboard mount to the transom.
I touched the fiberglass outside around the area where I had seen the crack (inside) and it is definitely stronger, but I could tell it had caved in a little (the 9.9 motor was/is currently mounted).
Can anyone advise me on hot I can repair reinforce this. Any way I had been planning on replacing the motor mount for a Garelick modern one, so this might be the chance to take care of all this.
Thanks,
David
Thanks,
David
