Safe transporting
I have now transported to boats over long distance. My 28.5 went from Montreal Canada to biloxi MS, and my "new" 34 was shipped from Havre de Grace MD, to Montreal, Canada. In both cases they are shoal draft, which minimizes total height. In boat cases, I used a hauler doing noting but boats, and was not asked about total height. vThe transporter should know, and should also be aware of all difficulties such as low bridges, overpasses, etc, along the way. He also should get the necessary permits to cross each state. BTW, since the 34 is less than 12 feet wide, the carrier does not need an escort ! It is always better to prepare the mast yourself, removing everything, including spreaders. Secure everything inside to avoid damage. Then I suggest you get used carpeting, and put a 6 inch wrap every 2 feet. Be there if you can when the trucker loads the boat. And when it gets unloaded at the other end. Good Luck
