Spars Main Page
I'm going to try and attach the main web page for Rig-Rite. Spars, Rigging, and Hardware for SailboatsRig-Rite, Inc.63 Centerville Road, Warwick, RI 02886 USAPhone: (001) 401-739-1140 -- FAX: (001) 401-739-1149www.RigRite.com Spars - Masts, Booms & Related Hardware -------------------------------------------------------------------------------- Rig-Rite stocks the widest selection of Spars and Spar Parts available anywhere, from manufacturers around the world. If you need a replacement part for an existing Spar, or a replacement Spar Section (Tube) to replace a broken one, See Spar Parts, below. If you need a complete Mast or Boom Assembly for a new boat or for your current one, See New Spars. -------------------------------------------------------------------------------- SPAR PARTS You can find the Spar Parts you need by one of three methods: Spar Parts by Manufacturer - If you need an exact replacement Spar or part for an existing Spar, the easiest way to find it is by identifying the Manufacturer of the Spar. If you know who built your Spars, click on the manufacturer. The world's most popular Spar Builders are listed below, and have their own pages listed on-site. If you need a replacement Spar Part that is specific to a particular Spar Section, but are unable to determine the Manufacturer of your Spar, See Identifying your Spar Section. General Spar Parts, those not specific to any particular Spar Section, are listed below, by Category. One-Design Spars and Parts - A small selection of common boats and One-Design Classes have few enough variations to allow their own pages. -------------------------------------------------------------------------------- Spar Parts by Spar Manufacturer Click on individual manufacturers, below, for Spar Section and Hardware details. Kenyon SparsSpartan SparsRig-Rite SparsPearson SparsSound Spars Isomat SparsFranceSparKemp SparsSelden MastsSparcraft MastsZ-Spar (Z-Diffusion) -------------------------------------------------------------------------------- General Spar Parts by Category Rig-Rite stocks a large selection of Spar Parts. General Spar Parts - those not specific to any particular Spar Section - are listed below. Masthead Spinnaker Bails Spinnaker Halyard Blocks Masthead & Forestay Toggles Tangs & Rigging Attachments Spreaders Mast & Spreader Lights Spinnaker Cars Exit Blocks Exit Plates Spar Cleats Mast Boots Mast Wedges Mast Stairs Sheaves Sheave Bushings Sheave Axle Pins w/ Tab Sailtrack Gooseneck Slides Gooseneck Toggles Gooseneck Reef Hooks Boom Bails & Vang Attachments Boom Outhaul Slides & Cars -------------------------------------------------------------------------------- Identifying Your Spar Section For parts that only fit a specific Spar Section, (most anything that attaches to the inner or outer Spar profile) you must first identify the specific Spar Section that the Part attaches to. If you know the manufacturer of your Spars, simply click on the name of the Sparbuilder, above. Section profiles and measurements are provided in each case to help you identify your specific Spar Sections. If you don't know who built your Spars, check the Sparbuilders above. It is likely your Spars were built by one of them. Most Spar Builders put labels on their masts (usually at about eye level when standing on deck), and many have their logo or part numbers cast or stamped in their castings and boom end fittings. If you are unable to determine your Spar Section from the data on-site, we can do so if you forward a tracing of the Section and its Maximum Outside Dimensions. Frequent changes in boat models, constant design improvements, and numerous other variations, make it impossible for us to know exactly which Spar Sections you have on your boat. Please remember that Spar Parts are not specific to a particular Boat, but to the Spar Section to which they attach. -------------------------------------------------------------------------------- Spar Ordering/QuestionsWe now have technical data and descriptions of most common Spar Sections and Replacement Parts on-site. We also stock many less common items not listed here. If a part you require is not listed on-site, please forward a sketch and a complete description of the part, or its nearest equivalent on the website, and its measurements, including which Mast, Boom, or Spreader Section the part attaches to. If you don't know which Spar Sections you have, See Identifying your Spar Section, above. For Part Numbers, Data and Specifications, See: Spar Parts, above. For Parts Pricing information, See Ordering/Pricing, you will need Part Numbers. For Technical Assistance, Data, and Spar Replacement Parts not currently on our website, contact us with complete details. Frequent changes in boat models, constant design improvements, and numerous other variations, make it impossible for us to know exactly which Spar Sections you have on your boat. If your questions are about your existing Mast, Boom, or Spreaders, you must specify which Mast, Boom, or Spreader Sections you have. (See Identifying your Spar Section, above.) Please include all boat details, including boat model, length, and year of manufacture. For a quote on a complete Spar Assembly, See New Spars. To place an Order, See Ordering/Pricing, you will need Part Numbers. ~ Back to Rig-Rite Home Page ~
