Need some winterization help - please?
27
Hunter 1983 Cherubini 37 Cutter Solomons, Md
Hi all,
My first winter trying to winterize my 1983 H37c - all has gone well with the water tanks and the faucet lines, raw cooling water for the motor and the raw water cooling for the refrigerator - having trouble with the AC - it is a luminaire system that is raw water cooled - closed the stopcock and opened the strainer and turned it on but it is too cold to kick the compressor on so it is not drawing cooling water - any recommendations on how to get the lines flushed with anti - freeze???
Thanks
Jim
Sep 26, 2008
566
- - Noank CT.
Re: Need some winterizing help - please?
I agree with "duality" and blow the lines out, actually if installed correctly these unit should be self draining (except the strainer and pump) A shop vac that will vacuum and discharge air will be an invaluable tool in winterizing your boat for the future. May want to consider buying a small air compressor as well (one of the small tank less type by Black and Decker, less then $100 will work well. Good Luck !
5,802
That is a problem. One that I do not have because mine is a reverse cycle and I set it to heat. An air compressor will work as Mike points out. With my Mermaid I can actually blow through the lines. When I remove the hose from the inlet water I often have to prime it. I pour some anti-freeze into the hose and blow. I can hear the fluid going through the pump, the unit, and out the thru-hull. I could easily put enough pink stuff in there by mouth if I had your situation.
Sep 2, 2009
339
Hunter Vision-32 New Hamburg, NY
hand siphon pump works too
I use a hand siphon pump into the intake hose ... plenty of pressure to get the pink stuff through the system
