E
Ernie
Hi all,I recently had to have my '79 H33 surveyed due to a change in insurance companies. The results have me a little befuddled. First of all, the results state that,essentially, the whole cabin top and most of the decks suffer from a moisture level of 30% (or more). I think this is a little high, but the only DIY remedy I can think of is the "drill and fill with epoxy" routine. Would this be a good enough fix? Although the surveyor said he found all this moisture present, he did not find any voids.Secondly, The survey informed me that the cockpit sole was very high in moisture content and there were a couple af void areas present. My thought on repairing this is to glass in a new piece of plywood over the existing sole. Would this be sufficient or is it really necessary to cut out the old before putting in the new?By the way, yes, I did check out the archives, but it still left me a little confused.Something else that might be worth mentioning is that I don't seem to feel any sponginess in the sole, and I'm a big guy (6'3" & 250 lbs).Any suggestions would be greatly appreciated.Thanks!!!!
