I've got a H22 that came with a 8HP Evinrude long shaft, manual start. Last year as we were cruising around we found that this would get us where we're going (although not in a hurry, which is fine). However, when we were taking my parents out for a cruise we were greeted with a wide array of new and interesting noises and smells...
...just as the engine died. We took it into a mechanic, and lo-and-behold the engine fried itself. The best we could figure, the motor's water pump gave out and without a drink of water, the engine tried to cool itself using all the nice plastic and rubber bits (and some metal bits), which didn't work out too well. Since it'd cost around $1k to fix the engine up, and even that's not guaranteed to work, we're now in the market for a new engine.
From looking around, it looks like Tahatsu is the type of engine to buy, but I could use some help deciding a few things:
- Power - We had an older 8HP 2-stroke engine on there, and that seemed fine, but I'm not sure how much of the power was eaten up by age and grime. Should I step up to 9.9HP for this type of boat? Or could I safely step down to 6HP? I've heard that having more power but not having to use it is better for the longevity of the engine.
- Start mechanism - I hated our pull start. It never worked right, and was always a hassle. I always had to start it so I couldn't go prep for launching while the fiance started the engine. However, it looks like Electric start would have to be wired into our electrics or get its own battery.
- Brand - It looks like Nissan engines are just a rebranded Tohatsu, is this really the case? Should we consider any other brands?
- Length - Our current engine is a long shaft, but every once in awhile in choppy waves it would pop the prop out of the water, so I'm considering an X-Long (25") shaft. Anyone have any experience on these, or downsides to using a longer shaft?
