G
Gary
Peggy, I spoke to you on another forum....I was fed up with my marine head and decided to go with a Thetford 875 MSD. It arrived and I zoomed to the boat only to learn that it was just too big for my small area (Hunter 31). So....back to the starting line. I have cooled off and successfully removed all my head plumbing, and removed my sink which helped access tight areas quite a bit. I am now waiting on my Odorsafe hose, and have planned the routing of all the lines. Question #1 - You wrote: "Ahead of use, pump the toilet in the wet mode a couple of times to wet bowl (Marine toilets aren't designed to hold water, so you'll add with a cup ahead of solid waste)...switch to dry. Use the toilet, then pump enough times IN THE DRY MODE to move the bowl contents all the way to the tank...you'll have to figure out how many that is based on the distance. Switch to wet, pump 3 or 4 more times to rinse the bowl...switch back to dry to pump the rinse water all the way the way through".My tank is about 5 feet from the head and uphill. How many pumps (Raritan PHII) should it take to get fluid to my tank?Question #2 - How can you pump all the fluid to the tank in the dry mode? It seems that since you are pumping toward a vented tank, the air would bubble thru the fluids and thus, the fluids would remain in the lowest point of the hose. Maybe I'm thinking to hard, but it seems that there would have to be a check valve in the line to pump uphill. Question #3 - Do you know if anyone makes 45 degree 1 1/2" barb fittings?Thanks much
