Need perkins prima M50 fuel line replacement???
Mar 20, 2016
595
Beneteau 351 WYC Whitby
Hard to tell from picture ,it looks like a 1/8 BSP fitting or 1/4 bsp fitting.Get 2 x1/8 BSP or 1/4 bsp to 3/8 barbs and some 3/8 fuel line hose and you will be good to go
766
Hunter 260 winnipeg, Manitoba
Often the crimp on style fitting will have a normal hose Barb in the interior for the hose to slide on to. In the short term - assuming this is a low pressure application - you could cut the crimp portion of the fitting off (using a Dremel type tool) on the hose side of the hex and slide a new hose on the Barb and use one of the hose clamps you show in your photo to tighten the hose on to the Barb.
Likes: georgetheleo
Slotted hose clamps are not a good choice for fuel lines. A solid band clamp is better as the clamping pressure is equal and the band does not cut into the hose.
Likes: twalker H260
Jul 13, 2009
84
Parker Skipjack 37 Clearwater
I am planning on this if I cannot obtain new fittings from UK
Oct 2, 2008
3,811
Pearson/ 530 Strafford, NH
If the girls don’t find you handsome, at least they’ll find you handy.
Good news George. Guess you could call it a Christmas Miracle.
