New Sails
Hi Scott, I would suggest you go on line to Sailnet.com.Click on the AirForce Sail link, You can then on the spot get a quote for your boat. This is a rough (pre measured) quote but close, plus you can play with the options. You can also try Cruisingdirect.com which is the mass produced (someplace) related to North Sails somehow (at least the add says Manufactured and Serviced by North) I believe you have to request a brochure which explains measuring and calculating the price. Either way I would take this information and use for knowledge, then go to your local sailmaker and have him make sails for you. You will end up taking it in for service probably annually, and it will make life easier to have purchased your sail where it is serviced. I believe there is a North loft close to your boat regardless. It is also nice to have local knowledge in determining the size of the Genoa, Hight of the clew and other stuff. As a bonus, since it is now September, the sailmakers will start offering Winter discounts soon, if not now, if you ask for one. This is usually 15-20%. Someone else recommended Bacon ( in annapolis) I purchased a nice racing sail there, Only downside is you will probably have to have it modified to fit your boat.Have funDave
