I need the exhaust flange for now.
I have low compression in number two cylinder and have tried to get new piston rings from the Kubota dealer. It seems that the parts people in the northeast don't have Z-500 as a cross reference to this engine anymore. The exhaust flange (new) has to be back ordered with a 4 to 6 week wait.
Anyone know which Kubota engine is a good reference these days?
I've learned at least three things on this rebuild from past mistakes (not all my own), so here goes:
1. Don't ever use reuse the head bolts, even if you have to hunt new ones down; you simply have a difficult time torquing them properly and will probably bust a few at the next head removal.
2. Use anti-seize on the bolts, even though it is stated in many blogs that this will throw off your torque readings slightly (delicate genius rule Costanza IMHO).
3. Liberally use permatex #2 when installing a new head gasket. It will make the old one easier to remove by far, and you may be able to salvage the old one the next time (got a quote of $78 on a new one).
Half way through the project..."Chimay", how may I reach you. Thanks, Jim
