Propane Flow
Without knowing what you have tried so far and how much you know about propane systems, I'll risk boreing you with a couple basics. Besides the tank shutoff valve (which must be opened) there should be an electrically controlled shutoff valve which must be opened. It should be controlled by a switch somewhere in the vicinity of the appliance. With a voltmeter, check for approximately 12 VDC on the electrical solenoid. The solenoid should be installed inside the propane tank box. If not, it should at least be somewhere outside, but near, the box. The 12 VDC should be there when the switch near the appliance is turned on. Hopes this helps.Bob MillerGusty GetawayEverett, WA
