need info on 33 cerubini
2
- - buffalo
WE are considering buying a 1981 ( I think) hunter 33 cerubini...how is this different from a regular 33? What should we look for as far as common problems? any advice anyone can give us whould be greatly appreciated. We now have a CAl 25 and sail on Lake Erie
Sanders
See forum, archives, owner reviews
The basic difference is that Hunter boats in that era were designed by John Cherubini, and came with certain features that have made them popular. Go the the list of Forums on this site and find the Cherubini forum, then when you get there do a search on 33 on the left side of the page. You'll find specs etc. Then try the owner reviews on the 33. Then do an archive search. You'll find a ton of information dealing with specifics through the years.
O
Okiman
Inspection points
First make sure you get the boat surveyed by a professional surveyor. Here are some major points of concern that I had to deal with on my boat after I bought it. 1. Crawl into the stern and check the cockpit drain and steering plate under the binnacle. 2. Check throttle and gear shift cables for smooth operation. 3. Check out the wiring, if it looks bad, it is bad and unsafe 4. Usually the plastic ports are about shot and leak, and will need replaced Good luck.
