Need ideas for outboard motor lift...
wpage
May 26, 2010
5
hunter 25 stouts creek
Looking for ideas or better yet pics of solutions to the backbreaking problem of pulling up my 10 HP out board motor:confused:
I have a 25 Hunter with a tiller and nothing other than my Stay Cable to latch to:eek:
Please help:)
Thanks!
JVB
Jan 26, 2006
270
Schock Wavelength 24 Lake Murray, SC
Take a look at the motorized lifts on the big outboard engines and powered trim tabs. Maybe you can adapt one for your engine.
http://www.bennetttrimtabs.com/guidetotrimtabs5.php
http://www.bennetttrimtabs.com/hatchliftingsystems.php?cID=5
Another approach is a lever that you attach to the back side of the motor and extends several feet above the motor. The lever could be made long enough to give you mechanical advantage when pulled by hand or when pulled forward by a rope to one of the boat's winches.
Eric M
Sep 30, 2008
159
Island Packet 35 Jacksonville
I assume your outboard is mounted on some sort of bracket on the transom of your boat. On my J24 this bracket was spring assisted, so all you had to do was push down on the top of the motor, move the release lever to unlock it from the down position and the spring would raise the motor. The bracket I had was similar to this. WM Model # 11887981
http://www.westmarine.com/webapp/wc...toreNum=10106&subdeptNum=10447&classNum=10448
The new 4 stroke outboards are often heavier than their 2 stroke cousins so you may simply need a bracket designed with a stronger spring. Hope this helps.
Some Hobie 33's have a line spliced into the backstay a few feet off the deck. That line is used with blocks 2:1 or 3:1 to lift the motor out of its well. Could you devise a similar system?
Apr 19, 2010
15
hunter 25.5 West Point Lake
I found a long (about 12 inch) piece of alum and screwed it onto the lift release handle. I then tied a rope with a loop in it onto the motor mount. All of this in order for me to be sitting up higher (not leaning way over) when I go to pull the motor up. Just a matter of getting better leverage.
May 31, 2004
858
Catalina 28 Branford
I gave up trying to use the spring-assisted lift; I just couldn't get sufficient leverage from the cockpit to do it. Now, I leave the mount in the lowest position and tilt the engine out of the water. Much easier.
Jun 7, 2007
515
Hunter 320 Williamsburg
Use the boom
Attach the 3:1 block and tackle to the back of the boom and swing it over to the dock.
wpage
May 26, 2010
5
Thanks everyone. Thats some great data to digest!
I like the boom block and the suggestion B4 it & may use both...
Excellent feedback!
