david
I have an oday daysailor II mfg in 1982 i just purchased. ive washed the boat inside and lifted the front end to drain the water out from the cockpit and inner hull. there was a lot of water in the hull that never came out. theres probably a blockage near the drain that im going to try to clear, but there seems to be quite a bit of water that is getting into the inner hull. i was wondering if you have any ideas were this might be coming from. thank you for your help.
