Need Help w Ground tackle 260
John Baumgartner
I want to upgrade my ground tackle, I have the standard ground tackle that came with the boat I beleave the standard stuff is 5 ft 1/4 chain 100ft, Frotress Guardian Utility anchor 11 LBS, and a very short anchor roller. The anchor doesn't seem to fit the short roller very well. I have bought,tried and returned a Horizon 16.5 LBS Claw Anchor, Bruce Anchor Roller BRM-2. The Claw anchor didn't fit the roller very well and the two didn't fit the boat at all. If any of you,in ciber land have a better solution, I would sure like to hear of it. I did buy and keep a new Rope/Chain Anchor Rode 15ft 1/4 dia chain with 200ft 1/2 inch line. I'm espically interested in a system where the better half doesn't have to lift the anchor over/under the fwd life lines, but will store in the roller. Thanks Baums Rush
C
CORKY TROTTER
roller
My ground tackle is 14 ft of chain and 150 ft of rope with the standard danforth. 1. You lift the anchor is one solution. Even tho' I do I still hit the boat. 2. I have fabricated an extension to my roller using aluminum I got at a hardware store. I am no machanist but it does look fairly good. I just bolted it to outside of the existing roller. I moved the roller foward and the pin also. I even shaped it like the existing one. Unfortuntely I have not be able to try it out but it should work. I added about 6-8 inches to the roller. I just did not want to pull the old roller and install an new one, not knowing what the bolt situation was underneath. If you need a I could get a pic done and added to this. Corky
C
CORKY TROTTER
send
If you don't mind sending me your e-mail address it would be easier to attach it than trying to get it on the web site. I will to do both. I will try and get this done this eve when I get home from work. I have a meeting to go to but will try. ct
C
Corky Trotter
address
I have the pics but they won't post to the HOW site. It might take me awhile to figure that out. Here is my e-mail address so you can send me yours and I will attach them to a message. trothome@sbcglobal.net Corky
