Hello,
It is going to be a great season coming up. We have a slip in the Santa Cruz harbor for the first time. We have a new (to us) 2001 9.9 Honda outboard that runs fantastic, and new Sunbrella material to make covers on the way.
NOW the problem. During some of our trial and tribulations of stepping the mast every time we wanted to sail, we had some mishaps and the step/plate/hinge assembly got a bit distorted. So last year I ordered a new plate and hinge assy from D & R and knew at some point we would change the plate. I have removed the screws, some came out ok, but 3 of them broke off at the heads. I have drilled those out. I can not get the old insert out of the mast. I have beat it quite a bit but it has not even budged a millimeter.
Are these press fit into the mast? I thought of using heat to try and expand the mast section, but a bit reluctant as I don't want to change the strength properties of the mast. I am not sure if that would happen or not with heat applied from a small propane torch?
Has anyone replaced this plate assembly and has a few tips?
Thanks
Thanks
