Hi all,
The steering wheel on our 1984 Beneteau First 38 is a bit loose. Basically it wobbles a bit. I was not sure if the connection between the shaft and the wheel was loose or if the shaft was loose within the binnacle. Luckily, I was able to remove the BEN (French manufacturer “Bianchetti Electronique Nautique”) Marco Polo Compass and then gain access to the steering mechanism at the top of the binnacle. Everything within the binnacle is very tight and in good shape. The problem is at the aft end of the shaft where the wheel is attached. The connection is a splined shaft (1” OD with 18 splines) where the vintage GOIOT wheel attaches to the aft end of the shaft. After 29+ years of service the splines are worn and the wheel wobbles.
This design & method of connection seems quite robust but is drastically different than the current connections use by GOIOT, EDSON, etc. I am trying to contact GOIOT’s USA rep for assistance and spare parts as I am hoping that I can buy a new shaft & wheel.
Since we will probably have to replace the wheel, we are considering buying GOIOT’s Steer 'n Go Wheel or Lewmar's Folding Wheel. Of course, it will have to match up with the splined shaft on the binnacle.
If we cannot buy a shaft from GOIOT, then we will be considering having a local machine shop fabricate a new shaft – with the aft end (without splines) as needed for the current generation of wheels.
Has anyone else been down this path?
Pics attached.
Much thanks,
Doug in Lakeview
1984 Beneteau First 38 – Hull #178
Belmont Harbor – Chicago
Pics attached.
Much thanks,
Doug in Lakeview
