Need help finding looking part
4
Oday 40 Port Clinton, Ohio
I am attempting to find a complete plexiglas sliding door assemble to cover the Westerbeke instrument panel on my 1987 O'Day 40. I have attached a picture of the assemble which I believe was standard equipment. The assemble does not have any identifying marks and I have been unsuccessful in identifying a manufacturer. The approximate measurements of the assembly are 17 1/2" x 10 1/2". Any help would be appreciated. Thanks.
bruce cornell
replace
take the screws out holding the frame and i bet the plastic slides will fall out, then go to local glass works and get new set made. what goes together, comes apart...
May 24, 2005
4
Need glass and frame
I actually need the entire assemble (frame and glass)- the frame is broken in several spots. Thanks
May 28, 2004
175
Oday Widgeon Beech Bluff, Tn.
Rudy
Morning: Have you checked with Rudy yet? If there is anybody that would have it, it would be him. If not, surely he knows where you can get it.
bruce cornell
beckson
the outer ring looks like a beckson port ring, the part looks like what is used in washdown systems on powerboats, only used for instruments.
