Another Replacement Idea
You could build a gimballed shelf then put a Kenyon one or two-burner butane cartridge stove on the gimballed shelf when needed. Actually, you could leave it there all the time and build a cover for it that would double as a cutting board. No oven solution here, but I personally don't use the oven that much.I too, will be replacing the stove/oven (eventually) and replacing with shelves on an H31. I love the little Kenyon, it boils 10 cups of coffee in 3 minutes. Better than LP IMHO, no tanks, no lines, no sniffers, no solenoid, no refill problems, no corrosion problems, less storage problems.Not as good as LP: No oven.Better than CNG: See LP above.Not as good as CNG: No oven.Hmmmm....does Kenyon make a butane cartridge oven? Now there's an idea. Regular gimballed stove and oven with two butane cartridges, one for stove and one for oven. Does this exist? If not, I'm calling Kenyon; or better yet, maybe I could build the dang thang.Overall disadvantages: Butane cartridges require storage. You can store approximately 20 cans in the same space as one 20# LP tank and it lasts longer. Oh, shucks, that was supposed to be a disadvantage. You can store 6 cans in the same space as a one gallon container of alcohol. If the fire goes out in the middle of cooking, you will have to replace the cartridge which takes almost 5 seconds, then relight by turning the knob. Did I mention I love my little Kenyon?
