How I do it...
Hello Jeff, I occasionally get hired to dive boats to clean the bottom, check the state of the zincs and thru-hulls, clean the prop, and so forth... Here's what I use. I have a 3" paint scraper (on which I rounded the edges) that will take just about any moss, barnacles, or stiff growth off with little effort. I have a pot scrubber- the synthetic steel wool with a plastic handle- that works well on stubborn soft growth, and is good for props. I use a regular scrub brush to get rid of the waterline scum. This combination of scrubbers removes 98% of the bottom growth on boats in my area, and isn't too hard on the bottom paint. I understand that people will use different tools or chemicals based on the waters they sail in; for example, I don't get the brown bow/waterline stains common to the ICW. You can also ask the boat owner what they prefer you use on their hull; they may even provide you with the tools. As for rates, I charge people around $25 per hour for my diving services, and I usually round down a little for people I know- If it takes me 1 1/2 hours, I'll usually charge $30 and a couple cold beverages. ;o) This is cheap for underwater services in my area- The pros make about $40-55 an hour. A 25 foot sailboat takes me about one hour to clean.Ask around to find out what's reasonable in your area- If everyone else on your lake is also a diver, then you probably won't be able to charge as much as you could if you were the only diver in town. Good luck!--Jon BastienH25 'Adagio'
