The only place your DC circuits and your AC should meet is at your battery charger and your inverter.
Exactly.... I made the mistake of adding an AC ground to the engine....I'm very familiar with DC, and made a mistake. I promise all of you, everything else is wired properly. I replaced my faulty extension cord with a proper 30 amp shore power cord, and it's all cool. I mean, its still just wire's to accessories right? beside the fact that it's 3 wires instead of 2, and it's AC instead of DC, its basically power in, power out (and the 3rd wire). Not only did i wire it exactly like the old wiring (except my own added engine ground), I did make a diagram. Just to clarilfy, I drew it out on paper (albeit by hand), I removed old wiring from accessories as I installed new wiring, I did it one wire at a time, matched my diagram, and tested individually. I did lots of net research as I did it, but I still screwed up with that AC engine ground. I understand better now. Im getting a survey soon, and I will triple check with the surveyor, but Im pretty darn sure it's right now. The AC being connected to the DC side through the ground was not a good idea.
I do have an excellent digital DC diagram I will post for your thoughts, after I find on one of my 6 scattered pc's once I find it. I will try to make an AC version for your comments soon. The AC wiring was original, and certainly could have used rewiring anyway ('86), so following it should have sufficed.
My mistake was that I mistook some wiring in the engine compartment. It was disassembled there, and wiring from the Heart inverter joined the AC system in the engine compartment, and I assumed it was connected there. I removed the destroyed inverter and traced the old wiring to its disconnected point, and assumed it's connection point was at the engine block along with the DC. Everything else was connected straight from breakers to accessory. and it matched what i planned on paper.
Im a little bit of a renegade hippy with short hair. maybe a redneck (not). I dont have the money to do a lot of things. I try to do it right, and it has taken me over a year so far, and maybe another 3-6 months if I make it pretty. Thats why I'm on this forum, to learn, and to figure out stuff. I can't always afford a book for everything. I cant afford a professional. Thats my life. if i want it, i gotta do it. I have a new young bride, and I make s#!t for a living. I can't take away from her, but I still want this. So please understand my unorthodox ways. Life wasnt supposed to be this way, but it is, and i still have a dream. No, i dont want to be electrocuted to death, but I do take risks like touching DC wires that were improperly grounded with AC. What else do I have to live for!
I wish you guys could see my boat. See what I started with, see what I have now. Completely by myself. 0% help, except what i got from this site. I thank you all. I moved the entire cabin (including sole) of this 40' boat, piece by piece, from a storage unit 6 hours away, in a Honda Fit (tiny hatchbatch), and installed it all, like a puzzle, with no directions. I learned a lot from this site. I have a YACHT! and it's beautiful! I know her inside and out. if I ever have a problem, I know how to fix it.
Live or die,
