I rewired my 86 hunter 40, and now I get a little shock when I hold on to a pole and touch something on my distribution panel. Its a ss support pole from the cabin top down to the bilge.
obviously something is wire wrong. I grounded the green wire from my panel to the engine block. is that right? also my dc is grounded to the engine.
I also noticed another shock. I was working near my hot water heater and got a shock when i touched 2 adjacent pieces of the unit. I can touch any part of the unit, but when i touch 2 places at the same time i get a shock. any ideas? I guess i need to take the cover off and examine the wiring. probably something touching inside.
I have an a/c charger onboard-40amp truecharge. it is hardwired to the panel. other than that, I have a/c outlets, refrigerator (just installed, so that isnt the problem), water heater, and thats about it.
Im on the hard and Im using an extension cord and adapter for 30amp shorepower. I have breakers at shorepower in, and on distribution panel. The ground is a big post connected to the engine with a/c & d/c ground attached.
thanks for your help. im trying to finish up and launch soon!
