My friend's new to her boat has a CDI Furler which I believe is an FF3. But it does not exactly look like what I see in the current online FF3 manual. The internal halyard is wire with what appears to be a small and weak shackle. At least for a big heavy 150 on a Hunter 28.5. Then the front of the furler does NOT have the internal wire exiting with any way to shackle it to the drum. Instead there is a tab with a hole that goes up and down in the slot. The previous owner left a carabiner attached. So my assumption is that the wire halyard with the small shackle attaches to the head of the jib. Then with a line attached to that tab the sail is pulled up into the slot. Somehow then that tab is secured to the drum and the sail tack as well. Mysteriously there are only two holes on top of the drum. One is open the other is closed, there is nothing to connect either the tab nor the sail tack. Appreciate your experience and comments.
P.S. Unfortunately the previous owner, a good friend, is unable to help due to health issues.
