Need Beneteau 41 Masthead Pictures
May 25, 2013
36
Beneteau Sense 50 Waterford Harbour
I need some close up pictures of the Beneteau 41 masthead area. I'm going to mount a wifi antenna and need to do a little planning for the mount and cable routing....to minimize running up and down the mast. I'm interested in the port and starboard side views from the forestay attach point to the masthead including the feedline exit locations. If someone has their B41 mast unstepped and can help, that would be appreciated.
May 25, 2013
36
Thanks. I'm looking for actual as-rigged photos of B41 mast top sections. May have to get the telephoto camera out and see what I can capture .
Apr 13, 2011
32
Beneteau 40 Chicago
Here's a photo for you
I had the PDQ Connect AllPro Ethernet Wi-Fi Amplifier with Router from Defender installed.
Works great.
Before you install it:
I suggest you exchange the 50’ wire with PDQ (contact info below) and get a 60' as it will be enough, as you will have to leave a bit extra at the top and come through the drilled holes near the mast base to connect underneath inside. As far as the connection from the mast base to the nav station, 25’ is sufficient.
PDQ Contact info:
Monday - Friday, 8:00 AM - 5:00 PM Pacific Time
7323 Engineer Road
San Diego, CA 92111
Phone (858) 598-2359
71
Beneteau Oceanis 45 Rock Hall, MD
Something I noticed in reviewing my photos is what seems to be an extra run of coax on this 41. I need to see if my 45 has this, although I believe I already have two VHF antenna, so it maybe in use.
I realize I now need to photograph my mast. :doh: I want a rigger to install my WIFI Bullet and a Glomex TV antenna.
