Having second thoughts about mounting my new electrical panel forward of the shunt(pictured). I was working in that starboard locker on Monday and realized how hard it is going to be installing all that wire up there. So I am thinking about mounting the panel crosswises, between the engine bulkhead and the icebox. I would glass 1x2 onto the icebox and screw a like 1x2 just forward of the shunt.
So if one of you lucky owners whose boat is close by could measure that I would be grateful. I could almost calculate from the picture. But I can't remember if that battery is against the icebox or under it. I just need a rough estimate to see if my combiner, relay, and bus will fit.
Kills me to throw this much wire away. Two pieces are 14 footers. And the switch has a crack, might be time for a new one. You can see why I am concerned about getting three 1/0 cables onto that switch. It sits in a hole only 3 and 7/8". Maybe a new one would be bigger.
