My Allied Seawind has a horizontal barrel windlass. After removing the right side (chain side) pieces, cleaning and reassembling it, it slips badly no matter how hard I tighten the side wheel that pushes the friction plate against it. There is no lubricant of any kind on any of these pieces, so it is not a case misapplied lubricant like sometime happens when winches are greased. I don't believe I lost any pieces, but just in case here are the parts:1. The outside nut with spokes. This is what is used to engage (tighten) the clutch. When turned clockwise, it pushes the (2) round cone-shaped plate that in turn pushes against the (3) larger plate that finally pushes against the (4) inner surface of the chain sprocket. There are no other parts.Any advice? Randals/V shearwater
