Good advice Bob.
Chris,One major question: Is this your first boat trip in this weather in the area you are planning to travel?If you are not sure of the motor, plan to sail part of the trip. The 6.5 at max power may give you just below hull speed, (that is a long time to keep a motor at full revs)5 to 6 knots or 6 to 7 mph. This does not take into account tides nor wind nor sea conditions. Bob is right. Leave early weather permiting and make sure that you have stops available along the way should you need them. If you are not sure of the motor, be prepared to sail if the power is down.Answer to your question: It might make hull speed but I would figure 25% less for your trip. At hull speed that is 10 hours in the best conditions. Figure two days and if you make it in one, you lose one day of being on the boat. Plan to enjoy your trip. I am sure weather is still pretty cold up there. Make sure you have a way to get warm. Let someone know your plan and keep intouch with that person. When it is cold, time is of the essence. Congradulations on the boat and I hope your trip is a great first trip. r.w.landau
