need advice for repainting deck of '76 27ft catalina
4
Catalina Dinette Model Cadle Creek, Mayo,Md.
Bought our boat last spring. Pale blue deck paint is worn in spots. Seeking advice for technique and products to use to get a good finish for most economical price. The boat is in the water at this time.
Thanks,
Patty and Jim
Jul 7, 2009
218
Catalina 30 Mark I Stockton, Mo
It's a little expensive, but I have had great results with Interlux Perfection. It's a two part polyeurathane that has some good UV inhibitors in it. So far, it wears like iron and is easy to apply with a solvent resistant foam brush. The only problem I have had is dust and junk flying around and getting stuck in it, but you can sand it and polish it to clear up any blemishes.
I used Mediterranen white on the flat stuff, and Matterhorn white on the anti-skid, and the contrast is just right.
Let me know if you try it and how it works.
Aug 10, 2010
1
Catalina 27 Everett
I just repainted my entire C27 this past June. For the Deck I used:
Deck - Pettit Easypoxy Topside & Deck in Gloss White - 1 QT.
Non-Skid - Interlux: Interdeck Beige (Deck Non-Skid Areas) - 1 QT.
Non-Skid - Interlux: Interdeck White (Cockpit & Companion Way sliding hatch) 1 QT.
Primer - Pettit Easypoxy White Undercoater - 1 QT.
4 Rolls of 3/4" Blue 3M 14day Painters Tape
I had old blue non-skid before and the 1 QT Beige was just enough to cover the deck areas with 2 coats. I only used 1/2 of the QT of White Non-Skid. The 1 QT of White Gloss was enough for 3 coats to cover the skid deck areas. I only removed the hatches, teak, cockpit lids, lines and easy accessible hardware from under the 1/4 berths. Make sure you sand and clean the fiberglass before painting on the primer. It took me 2 weeks to prep the deck and just over 1 week to paint it. I did all the work at the dock. If you paint the entire deck, make sure the skid/gloss area's are painted before the non-skid. I was able to get 2 coats of what ever I was painting done in a day, one coat around 7:00am, second coat at 8:00pm. All depends on the weather. I had to tarp my boat due to rain. The damp weather made the paint take longer to dry. I had a couple days where I could only get one coat on. While I waited for pain to dry I redid my teak. The teak was grayed and needed help. I sanded until I got to the nice warm teak color and then cleaned and varnished it with 9 coats.
Let me know if you want a picture. I took lots of them during the painting process and what I did.
Apr 6, 2010
39
Catalina 22 Deltaville
deck and Hull Paint Pictures
I would like to take you up on the offer to show those pictures you have of your newly painted 27. I am in the sanding and prep stage of my painting project and want to use the interlux paint also. I have thoughts to spray it. Anything you want to add to this?
Bobby
Deltaville, Va.
jamiehall66@verizon.net
