Need a spreader bushing (or whatever it's called)
bshock
Jan 18, 2013
126
Beneteau 361 Sandusky Harbor Marina
Hi fellow Beneteau owners. I have a 361 and lost a small thingamajig, which I will call a "spreader bushing." See pic below. It's the white, plastic sleeve that the spreader pin goes through. I looked on the Beneteau Spare Parts website, but found no luck. It referred me to www.charlestonspar.com for any parts not found on the Beneteau site, but that was a dead end too. Anyway, i need one of these little guys, and probably would order a handful just in case. Does anyone know the technical term for these things and where I can get them? :)
Any help is greatly appreciated!
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
that's a nylon bushing and they are sold by size ...od...id...and length you can get them on line if you do a google search ...they may come too long some times but a saw and sander will solve that problem
Beneteau 323 Annapolis MD
You can get nylon bushings at hardware stores, but you gotta know the size.
bshock
Jan 18, 2013
126
Thanks guys, next time I'm at the boat I'll get one of the bushings and will take it to a hardware store. :)
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
Why use the bushing at all? Just get a larger diameter clevis pin... Just a thought.
Nov 23, 2009
437
Beneteau Oceanis 361 Clipper --
Have a look at the attached file. It's part C, code 151183, from sparcraft in France.
By the way my boat doesn't have them. It has larger diameter clevis pins instead. I don't know if it matters but it's like this the last 13 years.
Was it a very big job to drop the mast? I suppose you are changing the standing rigging?
Likes: bshock
bshock
Jan 18, 2013
126
Thanks guys, I suppose I ought to have considered simply going with a larger clevis pin. Need to figure out that diameter now though.
Philip, thanks for the attachment, and the reason I dropped the mast, which I have done every year, is because I do indoor heated storage in the winter. It isn't a very big job for me, I just sit back and watch the yard crew do it. :) They use a crane that is on the lift while the boat is still floating in the well. Then once the mast is removed and stowed on shore, they come back and lift the boat out of the water and put it on the cradle. Easy peasy, and they haven't messed it up yet (knock on wood).
Gunni
Mar 16, 2010
5,937
The bushing is there for a reason, the pin and the spreader parts are dissimilar metals - you need to isolate them. Any competent rigger should have a selection of parts.
Likes: bshock
[QUOTE="... The bushing is there for a reason, the pin and the spreader parts are dissimilar metals - you need to isolate them. ....[/QUOTE]
... And metal on metal, one of them is going to take the wear and tear. Bushings are cheaper than spreader mounts or spreaders.
Likes: bshock
bshock
Jan 18, 2013
126
Good point! Gonna stay with the bushing. Thanks all!
DougM
Jul 24, 2005
2,242
... And metal on metal, one of them is going to take the wear and tear. Bushings are cheaper than spreader mounts or spreaders.[/QUOTE]
Not a problem in fresh water!,,
I would be more concerned about the bushing age disintegrating under load allowing the spreader to wiggle around letting the pin mangle the hole.
Gunni
Mar 16, 2010
5,937
You should inspect your rig every 5 years, and replace the standing rigging every 10. That was the duty cycle these parts are designed to.
