Need a refrigeration unit for the ice box
Mark Cote
Anyone install a refrigeration unit for the ice box. Looking for and easy install. 12 & 120 volt system.
Mike
Adler/Barbour
I installed the Adler/Barbour Coolmatic 55, Condensing Unit with the Adler/Barbour Evaporator, Series 50 O-Type. Condenser fits on the self in the port locker. Drill 2 holes for the piping connect the wires, and mount the evaporator. Make sure you have the batteries to run it. I put in 2 6V for the house bank with a 105amp alternator.
Mark Cote
Mike, Thanks, I did look at that one, but did not know if it would fit. I have two Batteries now, so you added another one and changed the alternator for a high output one?
Ron H
another refrigeration option
I recently installed an Isotherm refrigerator in my 86 C-30. It runs on DC only but there's really no reason for AC/DC if you have a battery charger to keep your batteries topped off at the pier. The installation was fairly easy. I put it where the three drawers are on the port side of the companion way. Had to remove the drawers and enlarge the opening a bit with a dremel tool. Whole job, including wiring took less than two hours. The fridge keeps drinks real cold & holds four ice trays. My boats only about two miles from the house so I spend lots of evenings there. It's really nice not having to lug ice down to the harbor every few days. I did lose the storage are of the three drawers but my next project is to remove the old alcohol stove w/oven, build drawers in it's place with a two burner stove top above it. But that's for another day. Good luck, Ron
Mike
Charging
Yes I added a good starting battery and a high output alternator. If you are going to go this route make sure your engine has the upgraded alternator bracket. Mine didn't and it cracked the gear cover.
C
C Robb Worthington
same as mike
I installed the same unit as Mike, though from England it is called a Waeco, and also installed two more batteries to handle it. It is great to have ice in those boat drinks. I also agree that AC is not necessary.
