We purchased our 2001 Beneteau 411 in Charleston last fall. Both Marine Airr systems worked just fine. It has the digital stats which provides for atuo changeover from A/C to heat. We just moved the boat to its permanent home port on Lake Superior and being a little cooler up here have just used the heat. It has been about 2 months since it was in salt water, and used in the cooling mode. I went to switch into cooling this past weekend and upon doing so the units (both of them) would kick out with the HHH error message displayed. This means no cooling water. When i run in heat mode the water pump runs fine and the system functions fine. I lower the stat so it calls for cooling, i can hear the switch or solinoid go on the unit and the water stops flowing. within a minute i get the error message.
How do I go about clearing out the lines, and is that nessecarily the problem?? Of course where they are mounted it is almost impossible to get at any part of them.
Can an Acid flush be done with the boat in the water??
Has anyone else had a similar problem after pulling a boat from salt water?
