Need a local (greater Boston area) shop that can bend and machine plexiglass
Aug 17, 2013
1,071
Pearson P30 202 Ottawa/Gatineau
Can we get more info to point you in the right direction?
it won’t be me because I am too far away, but knowing the scope of the project helps
Sep 27, 2008
159
Hunter 33 salem
Ok...
The material is 1/2" thick polycarbonate.It measures 26.5" x 29.5".
It has 18 thru drilled and countersunk perimeter holes.
On one axis, it is curved. maybe 0.75" over the 29.5" length.
I am quite comfortable with everything but bending it.
I suspect it involves heat....
So, If I screw up and have to buy a 2nd piece, it may = having it done by a shop
Apr 25, 2024
672
Fuji 32 Bellingham
Yeah, that is pretty thick to bend without a little bit of equipment. Sounds like this is a forward hatch replacement?
It is still quite doable as a DIY job, but takes some setup that you probably don't want to do for a single one-off job. Sounds like you've already pretty much figured that out and that's why you're looking for a shop.
If you do decide to have a go yourself, I can tell you exactly how to do it. But, it is a lot of work for just the one job.
dLj
Mar 23, 2017
4,520
Thanks all
This is the slide top to the companionway on the Cherubini Hunter 33.
While the original may have been curved - does it really need to be curved?
dj
Sep 27, 2008
159
Hunter 33 salem
It may not need to be, there will be some geometry re-do's if that's the case.
I am considering it.
