Need a local (greater Boston area) shop that can bend and machine plexiglass
Aug 17, 2013
1,090
Pearson P30 202 Ottawa/Gatineau
Can we get more info to point you in the right direction?
it won’t be me because I am too far away, but knowing the scope of the project helps
Sep 27, 2008
169
Hunter 33 Danversport, MA
Ok...
The material is 1/2" thick polycarbonate.It measures 26.5" x 29.5".
It has 18 thru drilled and countersunk perimeter holes.
On one axis, it is curved. maybe 0.75" over the 29.5" length.
I am quite comfortable with everything but bending it.
I suspect it involves heat....
So, If I screw up and have to buy a 2nd piece, it may = having it done by a shop
Apr 25, 2024
712
Fuji 32 Bellingham
Yeah, that is pretty thick to bend without a little bit of equipment. Sounds like this is a forward hatch replacement?
It is still quite doable as a DIY job, but takes some setup that you probably don't want to do for a single one-off job. Sounds like you've already pretty much figured that out and that's why you're looking for a shop.
If you do decide to have a go yourself, I can tell you exactly how to do it. But, it is a lot of work for just the one job.
Sep 27, 2008
169
Thanks all
This is the slide top to the companionway on the Cherubini Hunter 33.
dLj
Mar 23, 2017
4,759
Thanks all
While the original may have been curved - does it really need to be curved?
dj
Sep 27, 2008
169
It may not need to be, there will be some geometry re-do's if that's the case.
I am considering it.
