Does anyone know of a source for a 6 wire waterproof or weatherproof connecter to connect masthead wires at the base of my deck stepped mast? I can find 4 even 5 wired connectors but not 6.Thanks
Use 2 4-wire connectors at different heights......
...That way, it is not going to be too wide to interfere with halyard movement. That`s what i had to do with my radar connection and it works fine. Good Luck
You can buy weather resistant connectors at Newark.com at a reasonable cost. 2 to 5 dollars per connector. The waterproof connectors are very expensive. I installed a plastic 6 pin weather resistant connector three years ago when I rewired my mast. No problems as to date.
