NEED 1/2 INCH TEAK BULKHEAD REPLACEMENT
V
VICKIE
DOES ANYONE KNOW WHERE I CAN GET A 1/2 INCH THINK 4X4 PIECE OF TEAK? I PULLED OUT THE BULKHEAD PIECE STARBORD SITDE DUE TO WATER DAMAGE.
jr
just did the same job
I just did the same job on my 1978 C30, except on the port side. I ordered it through the local lumber yard. It was expensive thought, about $150 for the sheet of plywood. Good luck, hopefully the port is easier than the starboard!!!
Joe
Jun 1, 2004
8,360
Use marine plywood....
with a teak veneer. Lots cheaper and easier on the rain forests. Locally, check your yellow pages for wood or lumber specialties, exotic wood or lumber, marine plywood, etc. Here's an online teak source you might find interesting.
