Not to Belabor the Point, Red,
...but, aside from the certification issue you and Moody have pointed out, if these replacement bulbs are "Colored LED bulbs satisfy all brightness, distance (2 nm), and arc requirements set forth by the US Coast Guard for vessels less than 50m (65 ft.) in length", then it seems well worth the unlikely risk that the USCG will be inspecting my nav light bulbs for the reduction in amp hours which is huge (IE small water-maker's worth). And, they are most certainly not as likely to fail as the stock bulbs (at $20 a pop). It is understandable this isn't the point of view everyone would be comfortable with, but after a lot of thought, it seems reasonable enough to me. Rick D.
