If I do go with a Nanni or a 3YM30 (two engines under consideration at the moment), I realize the exhaust port is on the wrong side. I could either pump in the rear of the vessel or move the exhaust port to the port side of the boat. Probably want to move it higher because it is difficult to see the exhaust on the boat. Ed what did you and other do??
The weight difference should be a positive difference in the performance of the vessel???
Thanks,
Emil
