Y
yo-d-yo
Here's a strange one. It appears that I have a thru hull leak in my refrigeration raw water pickup. The strange part is that it only appears to leak when I am running the refrigeration and am drawing water in through the thru-hull.Fridge pump on / original thru-hull open -> definate leak.Fridge pump off / original thru hull open or closed -> no apparent leak.Fridge pump on using alternate thru-hull, original thru-hull closed -> no apparent leak.There were recent repairs to this thru-hull and I suspect that something was not installed correctly when they re-installed the thru-hull, but I cannot understand why this leaks only when water is being pulled in. I do not understand the physics of this problem.So far the boat has not sunk.
