Mystery solved? (Water Ingress)
Oct 19, 2019
921
Albin Vega 27 Limerick
I expect that very few have the patience to read this?
But I think that I may have found the primary cause of ingress of water.
As I suspected (one of my many suspicions) it was water running either
directly through the "hawse pipe" for the anchor chain (or perhaps
penetrating through the deck fittings in that area of fore-deck).
When I applied a power-hose to the hawse pipe this afternoon (while tied
up) , a significant amount of water made its way to the lower part of
the chain locker and thence under the water tank to the locker
immediately aft of it and then to the battery compartment.
The interesting part is that, when the boat is heeled hard to starboard,
this water floods under the starboard berth and so reaches up the the
water-line level in the lower part (under shelf) of the starboard locker
above the starboard berth.
This via the drain slot at the inboard side of the locker below the
starboard berth - which I expect was designed to allow condensation to
drain from the starboard locker to the bilge via the battery compartment?
In retrospect it should have been obvious as there is significant water
damage to the port side of the small bulkhead that forms the aft part of
the chain locker.
So I'll make a temporary rubber cowl to inhibit water ingress and over
the winter I'll find the exact cause and rebed as necessary.
The amusing (*gritted teeth* ) aspect of the whole palaver is that I
have replaced window seals (that needed replacing), tightened hulldeck
seals (that needed tightening), and resealed the cockpit sole & the
cockpit locker covers (that needed re-sealing) all in search of what
should (in retrospect) have been the obvious cause. :)
But all the above needed doing anyway so.... &^$%*&% :)
All the best,
John V1447 Breakaway
Feb 13, 2010
528
Congratulations, I know that is a relief. There is one thing about
water in a boat it is almost always from someplace else. The
problem is which someplace else to look in first. Doug
On 11/08/2014 05:22 PM, John Kinsella
John.Kinsella@... [AlbinVega] wrote:
Nov 8, 2001
1,818
Well done John. In the 20 plus years i have owned
Vegas I have always had some water in the bilge and just left it as never caused
a problem. I now feel like ensuring I have a perfectly dry bilge. Now... where
do I start!
Steve B
[AlbinVega]
Sent: Saturday, November 08, 2014 10:22 PM
To: AlbinVega@yahoogroups.com
Subject: [AlbinVega] Mystery solved? (Water
Ingress)
I expect that very few have the patience to read this?But I think
that I may have found the primary cause of ingress of water.As I
suspected (one of my many suspicions) it was water running either directly
through the "hawse pipe" for the anchor chain (or perhaps penetrating
through the deck fittings in that area of fore-deck).When I applied a
power-hose to the hawse pipe this afternoon (while tied up) , a significant
amount of water made its way to the lower part of the chain locker and
thence under the water tank to the locker immediately aft of it and then to
the battery compartment.The interesting part is that, when the boat is
heeled hard to starboard, this water floods under the starboard berth and so
reaches up the the water-line level in the lower part (under shelf) of the
starboard locker above the starboard berth.This via the drain slot
at the inboard side of the locker below the starboard berth - which I expect
was designed to allow condensation to drain from the starboard locker to the
bilge via the battery compartment?In retrospect it should have been
obvious as there is significant water damage to the port side of the small
bulkhead that forms the aft part of the chain locker.So I'll make a
temporary rubber cowl to inhibit water ingress and over the winter I'll find
the exact cause and rebed as necessary.The amusing (*gritted teeth* )
aspect of the whole palaver is that I have replaced window seals (that
needed replacing), tightened hulldeck seals (that needed tightening), and
resealed the cockpit sole & the cockpit locker covers (that needed
re-sealing) all in search of what should (in retrospect) have been the
obvious cause. :)But all the above needed doing anyway so....
&^$%*&% :)All the best,John V1447
Breakaway
This email is free from viruses and malware because avast! Antivirus protection is active.
Jan 28, 2001
694
We took significant amounts of water through the hawse pipe during our storm experience going to Mexico. Discussing it with other cruisers we found out about using modeling clay to make a temporary and disposable gasket. It takes a lot to wash it out but comes out easily when time to drop the hook. It can also be pushed into the chain links if you are using an all chain setup. For passage making we were told about using spray foam to seal the hole. More difficult to wash out but easily removed when time to anchor. We never had opportunity to need that method and no longer environmentally correct but it was a thought. Walt, Lyric To: AlbinVega@yahoogroups.comFrom: AlbinVega@yahoogroups.comDate: Sun, 9 Nov 2014 09:54:44 +0000Subject: Re: [AlbinVega] Mystery solved? (Water Ingress)
do I start!
Steve B
[AlbinVega]
Ingress)
Breakaway
